Hi guys, im hoping someone can help me score some serious brownie points with the mother of my new ladyfriend. THe problem goes like this: (You'll quickly pick up that I'm most definitely not a plumber so please be patient).
Her house has a hot water tank on the 1st floor. THe hot water reaches most of the house fine, with seemingly good pressure and flow. However, the bath HW tap has very poor pressure as does the shower. (Bathroom is next to the airing cupboard with HW tank in it). The shower fails to get anything over lukewarm. THe shower was installed about 6 years ago and although never wonderful, did used to get up to temperature. Running down from the ceiling above the shower are 2 pipes feeding it, the hot one gets very hot to the touch when the shower is on despite the fact that the water flowing from the shower is cool. (To me this indicates poor flow?)
In the airing cupboard are 3 taps controlling the flow of the hot water around the house, and the one on the pipe for the bath is stuck solid with the red turning handle bit lost:
My assumptions are:
The pipe that feeds the bath and shower is partially blocked. (Or having re-read the post the tap is partially closed???) I would hazard a guess that the pipe that shoots downwards is the original and feeds the bath, while the one that goes upwards is the more recent addition and feeds the shower. Does this sound like it fits convention? (Im fairly sure the join at the top of the image is a T piece rather than a 90 deg bend, although I only had a 5 minute look the other day so may be wrong....(If it is indeed a 90 then the pipes in the bathroom must tee off from the bath, run up the inside of the wall then down the outside to the shower, which seems a bit long winded).
How do I turn off the system so that I can bleed the water from the pipes and remove the valve in the picture? I would hope to find it caked in scale or something which I can clean, then bask in the glory that awaits me....
If that is fruitless then the only thing I can think of would be that both the shower mixer unit and the bath tap are a bit scaled up. Is it possible to strip a shower mixer (it has 2 knobs, one for temperature and one for flow) to clean, and if so what would you use? I had the Idea to turn off the hot water supply, drain the shower, then turn the tap on and back fill the unit with a limescale removing solution. Would this kill the internal seals? Any help/ideas would be gratefully received. Thanks in advance. Adam.
PS In return I am a turbocharger engineer so If anyone wants to know about Turbos Ill happily trade information!
PPS Just re-read again, and if the join above the questionable tap/valve is indeed a tee, then this valve will have no effect on the shower. On or off, blocked or not the shower should still work.
My head hurts.
My assumptions are:
My head hurts.
