Evening all. New bathroom fitted (ish- think the fitter used his dog to cut the panel edges but that's a story for an episode of Cowboy Bathrooms). Anyway, meat of the question- pop up wastes, does anyone like them and which brand pops the waste up by more than about 6mm (currently the waste doesn't keep up with the shower).
The one fitted would work OK if I could extend the cable inner (or shorten the cover)- if it was operating in a straight line there's about 20mm of movement available on it, soon as you bend it to suit the way the Lone Ranger has set the waste, the available travel drops to about 10mm. There is some scope to refit to reduce the bending but not much........ options are a new one (if you lot know of a brand which works better) or just stick a normal plug on a chain job in
Thanx
Thanx
