I've got a potterton performa 24 boiler which has stopped working? Its got power, pump starts when either central heating or hot water is turned on but the boiler doesn't ignite. When the hot water tap is turn on the pressure differential part of the valve works which presses the micro switch on the front. When the central heating is turned on the hot water priority part tries to operate but doesn't seem to have enough movement to press the micro switch. If I operate the micro switch manually the boiler ignites and heats the water. Hope this makes sense and someone can point me in the right direction.
Cheers in advance.
Cheers in advance.
