I have read a number of reviews online about lockout problems with the Potterton 50 Suprima. However my symptoms seems to be slighly different and wondering whether it's the PCB which needs replacing. Can any of you experts advise what the problem may be based on the following:
All thermostats are calling OK (room and boiler)
Three way valve is opening and closing
Pump is running free (system has recently been flushed)
All rads and hot water tank are reaching temperature OK
It seems after the boiler has been running for a while it will lockout (even when the stats are calling) then ten to thirty seconds later the pump will start to run - and will continue to run until the reset button is pressed. And if this is done soon after lockout the boiler won't always reset!
Can anyone help?
Can anyone help?
