The boiler flame cuts out - probably due to water temp as usual - fan stays on,then will not come on again and goes cold, but the water pump and water solenoid vaves remain open (ie power is there). When the programmer is advanced to off and then turned on again the boiler fires up. The period that the flame is on varies - and to complicate matters the fault is intermittent, sometimes the boiler does fire up on its own as it cools. Could it be a pilo light ignition problem.
(An 'engineer' came and diagnosed a circulation problem and changed the water pump, but no improvement!!!)
