Potterton blowing fuses
14 Feb 2004
I have a Potterton Suprima 40. It keeps blowing the fuse in the FCU. The fuse on the PCB is OK. The boiler powers up when I disconnect the overheat thermostat, but it will not ignite.
The overheat thermostat is a dead short , so I guess that it is faulty. There must be a short somewhere else as well. I guess it might be the PCB.
Any help appreciated.
The overheat stat is SUPPOSED to be a dead short until it gets to 95 or so!
FCU??
Could be a motorised valve, pump, gas valve...
Chris R, Thanks for the reply. I checked for shorts in the wiring and on the valve etc. and could not find any. I removed the PCB and found some discolouration on the traces. I read the fault finding guide again and realised that the overheat stat is supposed to be closed. The fuse only blew when the overheat stat was connected
I bought a new PCB.
Boiler now working.
