Good Afternoon,
I am looking for some help with my boiler / control system.
I have recently moved into a house with a Potterton Profile 80eL boiler installed to a gravity fed system.
I was setting up the days/times on the programmer yesterday and realised that when the central heating is called for the pump will run but the boiler does not ignite.
If hot water is called for the boiler will ignite.
At the moment I am having to run the hot water and central heating at the same time to get the central heating hot, which is using quite a bit of gas!
A contractor has looked and advised that the current programmer (Honeywell ST9400C) is not compatible with a gravity fed system?
I have a feeling that this may not be true as the spec sheet stars that it is compatible with a gravity fed system.
Anyone have any ideas?
Many thanks!
Many thanks!
