Potterton Kingfisher2 CF80
15 May 2005
Sussex
Anyone know where I can get a complete H/Ex (Part No 204382) for this leaking boiler? Tried the usual but as it's obsolete according to Interpart no ones got one. New boiler would mean new position and plenty of headaches. Besides, system piped in barrel so don't really want to put in a condenser if I can help it.
I cant see where it's coming from. It's dripping down onto the burner. It may be one of the O rings between the sections. However, I'll need to remove it and pressure test to prove this. If one of the sections is leaking then obviously this work will have been in vain, something I'm trying to avoid. I take it replacing the O rings is reasonably simple?
I think you'll find all parts are available as separate items. Strip it down and rebuild as necessary?
Thanks bp. would you suggest renewing the tie bars? Do these need to be tightened to a specific torque?
The sections will be joined with tapper nipples, no gaskets or orings.
The section will be cracked and un-repairable, and not even a baxi man will get it apart without further damage.
POTT 8204382 HEAT EXCHANGER 68KG
£725.39 + VAT
Parts Center no 450745
The above price is trade :shock:
Is it really worth it? A new boiler would be about the same price
I cannot speak from experience with this boiler but Baxi used gaskets on many cast iron boilers!!
Em, yes they show an O ring kit pt/no 906940
The waterway are seperate if you can get them
Left hand 336-803
right hand 337-806
Intermediate 382-367
Tie bars 358-140
Left hand 336-803
right hand 337-806
Tie bars 358-140
#~~~~~~~~~~~~~~~~DOITALL~~~~~~~~~~~~~~~~#
No hard feelings I hope regarding my last post. I think it was simply a missunderstanding, from a Very experianced point of view i.e. (yourself) to a very new beginner, but willing to learn (myself)
Take it easy
The 'o' rings are avaliable and a half day job will have your boiler leak free for about 10 years.
A pain of a job in labour terms, but not difficult.
Dave
Update:
Removed H/exchanger and pressure tested. One of the intermediate sections was leaking. Managed to get hold of one plus all the 'o' rings. Stripped and rebuilt. System now up and running and one very happy customer. Not a particularly difficult job but a fiddly one.
Thanks for all your replies.
