potterton netaheat busted
26 Aug 2006
I have a Potterton Netaheat Boiler. It was cutting out after a couple of minutes and then switching off and on every couple of seconds. I replaced the PCB (with a second hand one)and it worked! For 2 days. Now it doesn't even try to light. Is it worth trying a new PCB or will I bite the bullet and get a new boiler
Hi there,
Personally, I'd change it. Its an old boiler and has had a good innings and parts are difficult to get hold of.
Good luck
garethgas, thanks for the advice, I'm hoping to get a wee while more from it, maybe I'm asking too much of the old girl.
ollski, it is a Netaheat electronic 10-16, cheers
I agree with both the others guys...I'd go straight to the APS or the fan itself and check those first.
garethgas
Ollski... I thought the only 2 netaheats were the 10/16 and the 16/22?
so did i but apparently their are over 20 versions :shock:
garethgas
fan seems to be working, what's the APS??
Please don't mess in this one, it needs a pro to go inside it....they can be death traps. The aps is the disc thing with the plastic pipe on it, the fan creates a pressure differential which moves the diaphragm inside to make a microswitch.
You need to measure the air pressure it's generating - get someone who knows the boiler.
There was a 6/10 as well. Then MkI, II, F and Electronic. I think I've got 5 different MI's!
Oh, in case anyone thought I forgot - there were Netaheat Profiles :D
I think that "Bab" mentioned the Netaheat Profile 50 min before you!
I dont know where Lanchashire comes into it though!
