- Joined
- 30 Dec 2017
- Messages
- 3
- Reaction score
- 0
- Country
Hello
First post but long time reader so I hope someone can help.
I have a Potterton Performa 28 boiler which has been serviced by British Gas (BG) annually and has never had issues. It is probably 10 or 12 years old.
The central heating works perfectly. Radiators nice and hot all over the house.
Hot water is a different situation. The boiler will not deliver a consistent stream of hot water in the kitchen or the bathroom. Water will run hot for approx 20 seconds and then reduce in temperature to tepid before gradually returning to hot, and then cold, and so on.
This cycle will repeat on and on.
I had BG in yesterday and their view was that the system needs to be powerflushed and at least the plate heat exchanger replaced (ideally both I have been told).
Given the cost, I would be interested in people's views. (I've already googled enough to establish that BG powerflush prices are extremely high so won't use them for that even if it is necessary.)
I would like to understand why a powerflush would help the production of hot water?
I could accept that sludge might build up in the central heating part of the system and that a lack of performance in that area may merit a powerflush, but the hot water system should be separate and I wouldn't expect it to build up sludge - presumably the water comes in through the mains, is heated by the boiler and goes out through the taps?
Can anyone help me understand the issue and whether I am being well/poorly advised by BG?
Many thanks in advance.
