hi problem with h/w open the tap boiler fires about 10seconds then boiler makes loud banging pressure needle bounces around and boiler cuts off not goin to lockout ?? pump??cheers
If it only happens on hot water i think it is a diverter issue not pump.....do the 2 pins one at back left and one at front both move and make contact before firing?
