Hi all,
When I switch on the central heating on this gas combi boiler, it supplies good heat to all of the radiators in the house. Each radiator is fitted with a thermostatic valve. After about 1 hour or so, the central heating operation neon extingushes and the heat flow to the rads stops completely and the rads cool down. I have tried increasing the thermostatic valves to the maximum on selected radiators, operating the reset function on the boiler, and ensured that the problem is not down to a timer (I have switched off the timer control and made the heating fully on.), but all to no avail. The direct water heating is not affected. Hot water is supplied to the taps on demand and the boiler ignites as required. I have also noticed that the boiler fan remains on for a long time, even when there has been no demand for heating/hot water for some time. For example, I checked at 4am, which is at least 5hrs after any demand for hot water or heating and the boiler was still 'humming' which I presume is the fan. Does anyone have any idea what this annoying problem could be?
