Potterton Powermax HE Boiler Lockout with A02 in display.
13 Apr 2012
Sussex
I have recently moved into a property that has the above type of boiler. It occasionally goes into lockout and displays A02. The boiler resets OK. It is worse it the CH is set to ON instead of timed. Could it be air in rads?
Have you ever had your boiler serviced?
Why do you think its not required?
Doesn't your boiler have a number after Powermax?
I have signed a contract with BG and awaiting the initial visit so there is a service contract in place so yes I do consider the importance!
If the cause of the A02 is something simple like bleeding the radiators then I am capable of doing that.
There is no number after the HE it literally says 'Potterton Powermax HE. I am aware of three different models but they are different capacity boilers so the functions will be the same.
A02 is a flame failure lockout condition. There is nothing you can do about this yourself. Not uncommon on these units and your repairman will be able to repair this fault.
Thanks for that, what I was looking for - a positive answer. I will get the BG man to investigate.
Be aware that BG will not start a boiler cover when its not working except at extra cost.
Assuming you have a gas supply, cooker working etc. then you would need a gas reg engineer.
It might be cheaper getting an independent in first as it might be something simple but that depends on the ratio of his costs to the BG extra costs.
Of course as its intermittent BG may not notice on their initial visit.
Tony
You are being very selective with what you are quoting!
It actually says thats WHEN there is no bypass fitted and all the rads have TRVs.
The solution might be to add an auto bypass if yours has none!
But I am always wary of an undocumented fault code which is not listed by a manufacturer. The implication is that its activated by overheating.
Tony
Have you read the link? Why do you want to add doubt to the explanation? I only quoted a minimum and pointed to the link for full explanation The guy has actually spoken with Potterton Technical I do not see any reason to doubt what he has stated. Yes a by-pass may be a good idea but if keeping a couple of TRV's fully open resolves the issue, especially as I know I have adjusted TRV's since moving in, problem solved.
If that is correct, and there is a lot of misinformation on the internet, then leaving some TRVs fully open would stop it happening again.
However, that is not the professional solution and negates the benefit of those TRVs left open.
I always prefer the proper solution.
Tony
Tell us, Tony, how do you leave a TRV fully open on a rising room temperature?
One radiator in the room with the room thermostat should be fitted with lockshield valves if overheating is the problem.
Most TRVs adjust up to a room temp of 28-30 which is unlikely to be reached during the heating season.
However, if in any doubt then removing the head will ensure it never turns off!
Tony
