I am coming to the end of my tether with this thing. The only reasons I have put off not replacing it is, other than cost, the fact that access is a bitch as its in a very tight cupboard in a small bathroom, and also the house its in is becoming flats in the near future (one year). After which I will need to redo all the bathrooms boiler and pipework anyway.
I have incessant problems with the pilot going out, the boiler cycling, and so on. When the heating comes on, it feels lukewarm anyway. I have bled all rads but they just don't seem to get that hot any more. Whereas, the circulating pump is boiling, as is the first bit of the flow pipe underneath, before the bypass.
I have had a loft conversion done which has extra rads in it now, so I wonder whether there is a problem with balancing, and whether I am asking a bit much of this boiler which would be better off in a flat itself rather than house with now five storeys. However we have come this far. Its just very annoying to have to check taps on various floors to try and work out why the house is stone cold when i come in.
I am debating whether to give the thing one last service, and have the heat exchanger replaced as well as maybe the PCB (or at least the Omron relays on it) as well as maybe the pump (which seems to be working fine but you never know), and the circulating pump, and the diverter valve (and the stats? And so on!)
I just wonder, even though the water that comes out of the pump and the rads is nice and clear, whether the pipes and/or the heat exchanger are a bit blocked and the system just needs a flush.
If I do replace it, what combi could take a big house with dozens of rads in it (two basement six ground floor six first floor four second floor two loft!) like this one can??
Any thoughts welcome.
