Potterton Puma 80 - No CH/HW
20 Feb 2006
London
My boiler no longer ignites for CH or HW - pilot light still on; everything else seems OK but -
Mains light has gone out, suspect this is why but what does the Mains light refer to, what are possible causes is this something i could fix myself
When you say main light are you referring to a neon light?? if so, Check your main switch or plug socket and check fuse.
mains light should be on constantly with this boiler :?
Your problem will almost certainly lie with the pcb which will be burnt out in the top left hand corner :?
this is a fairly common fault and replacing the pcb (printed circuit board) will sort it out :wink:
personally i re-solder the neutral wire or cut it and connect it to another neutral wire
Yes, but presumably you are not CORGI registered either!
