As we said before you need a CORGI to come and diagnose the fault. Its not anything obvious!
Tony
you need to bite the bullet and get in a corgi guy to look at boiler, pumps are prone to sticking causing overheating as is h/w microswitch sticking, might even be a problem with installation as the boiler has been moved. If its a fault with boiler they are not to bad to repair or diagnose, although beware or certain engineers, i.e dangermouse46, who cant repair older boilers and will tell you to replace it with a valiant, and then slag off bg just for good measure.
