potterton puma 80
28 Aug 2007
Essex
i have a potterton puma 80 combi boiler the hot water from the tap works ok when i switch to heating the boiler cuts out after 30 seconds pilot light and hot water works any ideas please
the guy that looked at it today thought it was the circuit board how much is the part you think it is also he said £175 for a ciruit board
many thanks
corgiman said:
the wax capsule diverter valve has failed
check no hot taps are dripping as this will also cause the same fault
many thanks
Unlikely if it fires up on demand..
The heat cant get anywhere due to wax capsule in diverter valve
partygirl said:
any idea of cost
Dont usually talk money but, id say to supply and install new diverter £180.
Really dpends on location etc
The entire diverter valve is about £100 and quite a nasty job to change. There is a little trick to make it easier though.
Sometimes its possible to just change the wax element, we do that for about £127 inc. Thats not a manufacturer supplied part though.
The latest diverters are redesigned so that the wax part cannot be changed! These Potty people are crafty.
Tony
News to me!
Perhaps they can be changed by some other means but they no longer have the removable nut at the front cold water end.
The only reason for the change would seem to be to stop just the waxstat being changed.
Where is Chris with his photo of one?
Tony
