Potterton Puma 80E Locking Out / Very hot scaly tap water
20 Aug 2008
London
Hi Everyone..Have an issue that is probably been discussed a few times. Have a Potterton Puma 80E Combi boiler that is at least 10 yrs old (I'm tenant in rented flat). For the past month, it has been "locking out" after hot water usage. Have to reset system by putting into standby. This now happens after each hot water usage (shower, washing up). We also have VERY hot water coming out of the tap at times, when the system has locked out (water is whitish and scaly). Had a guy round today, who after only listening to me describing the problem, said that HW exchange and/or diversion valve were clogged up. Recommended replacing boiler and power flushing radiator system. Said that the Potterton's were not very credible and that "repairing" after 10 years was throwing money down the drain. Comments or suggestions?? My landlady (South A. based) will have a fit and go into stall mode, unless I have some back up. [/u]
Well thats a very simple fault which we usually fix for between £84 to £119 in our local area depending on exactly whats wrong. I probably do one or two a month!
However if your landlady is stupid enough to send someone like that then let her take his advice and you will get a nice new boiler!
As you are the tenant, your only responsibility is to pay the rent!
I hope you have a current Gas Safety certificate?
I would guess that first its the DHW flow switch sticking on. But there also seems to be a temperature control problem, possibly pump not circulating ot DHW sensor o/c.
But whatever it is, these are totally repairable boilers.
