Potterton Puma 80e
13 Jun 2006
Hi
I have a Potterton Puma 80e (not sure how old it is as i have just moved into the house)
Recently replaced a radiator (like for like swap - no extra plumbing required) but did also drain down the system to give it a flush through as I doubt it had been done for a while
Now when HW is drawn (from kitchen or bathroom), 2 of the 5 radiators also come on (at the top of the house) - despite CH being switched off completely. Not good in this weather.
Does this sound as though the divertor valve has got stuck? If so, is it worth (power) flushing through again or just going ahead and replacing it?
Any help FULLY appreciated
The diverter valve does not shut off the heating circuit. It only opens a bypass route.
As a summertime remedy you could close one of the heating circuit isolating valves although be aware they often leak if moved.
You could either replace the whole diverter valve or if you are heavily into saving money you could remove it and try cleaning it out as its probably just rather bunged up. Perhaps as a result of loosened debris from the system.
A professional would have said dont fix it as it was working OK but of course as an owner you knew best!
Tony
Cheers for that Tony - i will do as advised (or a heating engineer will anyway)
Your point is well taken!
Alec
