Potterton suprema he lockout light
4 May 2011
Hampshire
Lockout light keeps coming on after resetting. According to the fault indicator its saying circulation problem. Any ideas please?
Since you're saying circ' problems you mean the lights are: (left to right) ON - FLASH - FLASH?
If so then yes, first check circulation, feel the system pump- is it vibrating? Is there water in system, can you hear water flow or air movement in pipes when boiler starts with a demand for heat?
The casting thermistor doesn't fail that often, usually after someone has been working on boiler and damaged it with the fan hood.
Have you had any work done, any prior symptoms, will it run at all- after reset?
Yes that's right red flash flash. Pump In airing cupboard feels hot? Got heating engineer coming tomorrow! Thanks
If pump is hot, and the boiler isnt firing, I'd expect the pump has seized up
The site FAQ explain how you can try to unseize the pump shaft!
Tony
Apprantley it was an airlock in bathroom rad stopping circulation. All working at the moment. Thanks.
