With that boiler you have a fully pumped system.Are you getting hot water? If so then as already suggested you would need to check your controls are working ok.You should get a pro in if you are not capable of fault finding.A better description of your controls would help.Select hot water only.....does it fire up and heat the water in the cylinder?
