Potterton Ultra problem
31 May 2006
Leicestershire
Hi
I have been unable to sort a Potterton Ultra 80. It is around 10 years old.
It lights OK, then within seconds cuts out and within seconds again, relights. This cycle continues around 10-15 times a minute. I have had the PCB repaired (as far as I know) by an electronics firm but it has made no difference. The fan is working fine.
Any ideas would be greatly appreciated.
Thanks.
Nigel
Often an airlfow problem, which makes it a corgi job.
Wait to have the p*ss taken out of you over the pcb...
Is the problem on the central heating or the hot water ?,or both ? :?:
he should have sent it to me ...
O.K chris r a.p.s or a.p.s tubes obstuction/split :idea:
Okayeeeee, So why the ch /hw query? Never seen one of these but they have a DV inside don't they?
All those I have seen have been a system boiler some with and some without a motor valve inside. They have all been installed with a thermal store although I presume they could also be used with a cylinder.
Sounds like the flame detection or the APS, both CORGI jobs.
Tony
