You don’t necessarily want to fill all the voids with something solid; in a stone wall, voids improve the thermal efficiency. Of course the stones need to be secure enough for the wall to not fall down. But you do want to stop draughts. I’d be tempted to mortar together the top layer of stones and not fill below there.
I'll be mixing in some hydrated lime but also dont expect it to fill at the very bottom as there is debris I cant get to from around the halfway point to the floor base.
fix a board to the wall with the top set level at the height you want the final poured grout to reach. If you just trust the existing plaster it may crack. If using Sika, you can pour another mix on top without waiting for the first to go off
