Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Put in some Sentinel X400 for a week, then cap off vent and feed pipes, then connect mains onto pump inlet and hose to drain from pump outlet, close all radiators except one, flush each rad at a time by closing rads on and off individually, when done reverse connections and start again, uncap vent and feeds, refill adding sentinel X100, works for me every time.
After such a flush is carried out, I suggest a water sample be taken from top of rad. You will be surprised to see cleansing chemicals in full strength in the sample while drainoff is crystal clear.
Back in my days at school in chemistry the rule was rinse 3 times. Based on that you'd want to drain (open bleed valves too), refill, bleed and circulate, 3 times to be sure it was all out. All valves open when circulating of course, or perhaps better still just one on at a time to make sure the water is pushed through each rad.
BTW. I found when draining my system for cleaning that the feed was faster than the drain so I could have the drain open and the pump on. That should have shifted a lot (still need to drain and refill to be sure thought).
