Hope I can get some good advise !
Over last few months the water flow has all but stopped from most of the upstairs taps and showers.
This is same for cold and hot water.
We have a outside pump to boost the pressure and our electrician has checked it and says its functioning as it should and cuts in to boost pressure when demanded.
This leaves me wondering if all the copper pipes are scaled up to the extent where is is now preventing flow.
I have read about power flushing but it all seems linked to heating systems and radiators, It it possible to do it on water feeds ?
Or failing that any other ideas / suggestions what could be causing the problem
