At present I have an electric shower but want to upgrade to a Power Shower, can anyone tell me how to go about this?
I guess that the pump would go on rubber to make less noise in the loft, I already have a 13amp socket and a cold water feed in the loft so I'll only have to get the hot feed, the easiest way would be to run to the loft inside the airing cupboard.
What I need to know is:
Where should I position the pump? There is no room in the airing cupboard? Should it go nearer where I get the water feeds from or nearer the shower?
Where should I get the hot water feed from? If it is from the airing cupboard the distance from here to the shower is around 15 feet.
From the pump do I just run pipe straight to the Power Shower?
There are 6 people in our house so would our normal sized water tank be big enough?
What HP pump would you recommend?
