Well, if the pump flow rate is higher than that of the main, then you'll be pumping water away from your neighbours and/or risking the ingress of impurities at points of negative pressure.
You would also aotumatically qualify for entrance into the National Stupid Competition.
At the risk of being accused of harping on about this, my point is that the OP didn't ask about the risk of whatever could happen when pumping the mains, but asked what would happen if he did it.
