Reading the different posts about extending a ring main, it seems this can be done either by creating a localised 'loop' to and from a single point, or by taking out a link between two existing points and replacing this with a new cable that runs through new points.
I would like to add at least 3 new points within a 3 metre stretch between existing points, and have managed to trace which cable runs between them. I would just like advice on whether there is any preference to using either of the methods described above, and if so, what the reasons for this are.
I should point out that the ring main is currently wired in conduit wire for live and neutral, and the earth is run via the metal conduit. I know that this is not a satisfactory method, but until I have the money to get the house rewired, this is what I'm stuck with. Thus whatever method I use, I realise I will have to preserve the integrity of the conduit. I plan to use T&E cable to extend the ring, and to ensure a good connection of the new cable to the earth terminal in the back of the existing metal boxes.
Anyway, here is the current situation:
Here is the 'loop' solution:
And the other:
It will not be any more or less disruptive to use either method, as the wall is being replastered anyway. Your comments much appreciated, including on the earth-via-conduit situation.
And the other:
