Hi has anyone got info on putting preheated mains pressure from thermal store tank solar panel heated into a combi inlet to top up heat for h. w .s Will it function O K?
There is a maximum temp that you can stick with some boilers if not all, have a look at the alpha or baxi gas saver bit of kit that should tell you max allowed
