Preparing a bathroom floor for rubber flooring
25 Nov 2008
Cardiff
Can anybody tell me what size screws should I be using for fixing 9mm ply to 18mm floorboards and at what centres should I screw them????
10cm around the edge and 15cm centers in the middle of boards. Screws need to be about 25mm+ or use ring shank nails of 25mm +. You will need to skim over the screw heads and joints with skim coat/feather finish compound to stop the screw heads showing through the new flooring.
