Preparing bathroom floor for lino
18 Oct 2009
Tyne and Wear
We've a wooden floorboard floor in our bathroom and have just had the bathroom done and have some 5mm thick lino to go down. I've read that it's best to line the floorboards first. Most people say use WBP ply. Would a waterproof plasterboard be acceptable too?? My thinking is that the plasterboard will be easy to cut and fit around the many different shapes behind and around the toilet which includes a cast soil pipe within the floor.
I presume you mean "vinyl"?????
Lino is a very old (but still available) product, and also one that is almost a forgotten skill - fitting wise!
sheet vinyl will eventually "mould" itself to any imperfections in the floor beneath it.
If your floor is not perfect then you need to board it first. traditionally this was done with hardboard, today this is done with ply. 4mm will suffice if your subfloor is not too bad, but most fitters will use 6mm. For a bathroom it will not cost too much and NO - do NOT use plasterboard EVER!!!!!!
6mm can be cut with a sharp Stanley type knife blade. you should also be able to create a cardboard template around any porcelain features and transfer this to your ply.
Or maybe you can remove the sink and loo before you ply - this will depend on the flexibility of your pipe connections though!
.....if not keep your templates for use on the vinyl afterwards!
"boarding" should be installed so that any joints are very tight and NOT over a floorboard joint
Fixing methods depend on whether you feel there may be a need to ever lift the floor - are there any pipes/wires/etc that may need future access?
If not cheapest and easiest is ring shank nails - fix every 4 inches around perimeter and every 6inches in middle they should be sized length wise so that there is no danger of hitting any cables or wires - this will depend on thickness of board and thickness of floorboards
If lifting may be required use screws fixed as above and with the same depth warnings
if in doubt - pop back with more questions
Cheers lymmranger.
Yes, I guess I do mean vinyl.
The toilet is coming out, and the basin is a wall mounted vanity unit so that's out of the way. There's some boxing around the internal soil pipe and what not which will need shaping. I was already planning on making a template as the spigot of the cast soil pipe for the loo is in the floor.
I have some aquapanel cement board left over. Would this be ok for the floor? Went to Wickes and all they had was hardwood ply and exterior ply so was unsure which to get. If the aquapanel is ok though I'll just use that. It's 12mm thick though but that shouldn't be a problem, and apparently it doesn't deteriorate when in contact with water. Seems far more substantial than ply.
Lastly, as all of the skirting is off, is it best to lay the vinyl then stick it down with tape or glue or just let it float and refit the skirting. Was thinking of maybe siliconing around the edge of vinyl and skirting upon completion.
Cheers lymmranger.
Nope - ply is best (full stop)
...........up to you and your trimming skills re the skirting boards
............I am not a fitter but an ex-retailer
............silicon can cause as many problems as it solves (stand by for outrage from fitters)
...........remember silicon will NOT stick to silicon - so you can only do it once - if you ever have to replace it or lift it you have no chance of it re-sealing
