Softus said:The flow, and therefore velocity, will be greater out of the tap spout when it's supplied by larger bore pipe.
9 l/min is 9 l/min, be it blasting down an 8mm pipe at very high pressure or running through an open gutter...I said:If we have a set flowrate of water
Softus said:The velocity along the pipe will be higher, but you won't be looking inside the pipe
I wasn't very clear when I said:chuck it down a 22mm pipe (open end)
I meant of course allowing the water to flow from an open ended pipe.
