Could anyone give a reason why the system is losing pressure.
It is an oil fired cooker which can either be used on sealed or open vented system as stated by m.i.
The system was originally open vented and is now converted to sealed.
There are 14 rads of various sizes 4 of which have new trv installed and 12 of the rads have aladdin auto bleed vents
There is a prv and aav on the highest point of the system
The ev is an 18lt and is precharged by factory to 1.5 bar
The filling loop is on the return line as well as the ev
The heating works fine except for the pressure loss
The pressure loss only seems to happen when the system is not on
So far i cannot see any leak on the system all connections are dry
If i pressurise the system to 1 or 1.5 bar after about 3 to 4 hrs it is reduced to .5 of a bar
The system has never worked as well as now all rads and cylinder are fully hot after about 1 hr
The reason the system was changed to sealed was that it was piped wrong and used to draw air in
The system has been completely flushed and an inhibitor added
