Hi
Need a quick piece of advice as to how best to prepare a ceiling for plastering.
The square extension we have had built has a double truss across the room between its two side walls. From this double truss there are a further 5 trusses (another double and 4 singles) that have been fixed from the side to side double truss to the end of the extension.
When we fixed the trusses we put a couple of truss hangers a little below the bottom of the truss they were fixed to. The side to side double truss is also fractionally twisted. The main problem is the second double trusses hanger which is about 7-8mm below where it should be. As a result the plasterboard when fixed to the ceiling looks a mess.
I don't want to remove the truss hangers, cut out the bottom of the trusses and refit as this isn't possible for all 5 trusses. I have on 3 of the truss hanger cut a slice out of the plasterboard, thinning it to fit.
How would you deal with the larger gap (drop). Is it possible to cut the plasterboard around the hanger(s), leaving it exposed and then fix a thin piece of plywood to the hanger(s) and plaster over the plywood.
Any advice appreciated
