I believe mycentral heating was fine before I had my extension built, it is a fuly pumped system with ahot water cylinder etc.
During the extension I have had several rooms added and the rads have about doubled, using same boiler ( potterton neataheat ) and pump.
When the CH pump is on low or medium speed everything is ok.
When I increase the speed to maximum, the makeup tank gets very hot and there is often a flow of very hot water returning through the expansion pipe.
My first thought was to raise the return pipe ( 1metre possible) to give extra `head` and hopefully stop the hot water eturn. Turning down the boiler temperature seems to have no effect.
I have just fitted a temporary hose which raises the return pipe by about 1 metre to see if this helps with the CH pump on full speed
Calibra
Calibra
