I've been called to a job to have a look at some lights that have been recessed into a terrace.
http://www.luckinslive.com/data/5097/PDF/20121030-JCC_Cat_25_p253.pdf
There are 8 lights in total and at some point, before drainage was put in, the first two lights had filled with water. So now after the problem of them filling with water has been fixed i noticed that the choke had become damaged from the water and so decided to replace them for the exact same ones.
http://www.bltdirect.com/product.php?pid=10926
I also decided to change the lamps and lamp holders so everything electrical inside the light fitting was new. The lamps that are being used are the TC-D 26W G24d-3.
The problem i've not got is that when i connect them up to either the mains coming into the light or a plug top for testing purposes the lamp either doesn't come on at all, or will flicker as if its trying to start but never actually start. Any help would be greatly appreciated.
I know have to go out for the day so excuse me if i don't reply immediatly. Thanks.
