I've got a problem with the Mixer tap in our downstairs toilet.
Basically the cold tap won't turn on. You can turn it maybe a quarter of a turn but that's all. No water comes out. It's as if it's seized up or something inside the tape has failed.
The warm tap is fine although the same mixer taps are in use in all of our bathrooms and on the other ones the warm taps are going the same way.
Can anyone suggest what might be wrong with the cold tap? Unfortunately there aren't any isolation valves on the taps so I will have to turn off the mains water to work on these.
thanks in advance. Photos of the taps and lower parts below.
