Problem with Shower
30 Jun 2005
Hi I have a Mira Play 9.5kw shower and today the water seems much cooler than usual on the normal setting I've always had it on. I've checked the filter also checked the resistance on both elements and they are reading around 16 ohms each also checked the solenoid and that has a resistance of 3.5 ohms which again seems normal?
Any ideas?
I do understand that the ambient water temp can affect the shower but it seems to much of a temp drop for this to be the case
Further to last post. Just measured incoming voltage at cu and barely reached 200v could thi be the problem. Have contacted supplier.
Cheers, contacted DNO Scottish Power who fixed problem at local substation within 2hrs. Bach up to 240v 😊
