I've just fitted one of these:
http://www.screwfix.com/prods/17552...ves/Adjustable-Radiator-Valve-Tail-Union-Type
but the connection between the tail pipe and the nut in the radiator is not tight and it moves if you pull the valve. Having looked at it I cant see any mechanism within the nuts at either end which causes the nut to clamp onto the tail pipe when they are tightened.
There are rubber O rings but these do not provide a seal around the pipe part of the tail and the nuts.
Am I doing something obviously wrong
or is this the way they are supposed to work?
Many thanks for any replies.
