Last time I had problems you were all immensely helpful so here's hoping again.
I have an old Potterton netoheat 10-16. It seems to have been working this morning because I have full tank of hot water. It was ok yesterday evening.
The house was cold so I turned the boiler on to heat the rads. Result loud screehing noise from the boiler but it fired for about 30 seconds then cut out. Ditto a bit later. Hot water then backflows to the header tank.
This was similar to my last problem when I got an air lock after a disaster replacing a rad. However not touched the system this time (never again.)
Last time I got the air out eventually to get the system to work but had to get a professional in to sort it out the rad. He eventually diaganised a blocked cold feed pipe which he repaired, along with the header tank valve and cleaned the pump etc. £550 thank you. (He was there 6 hours)
There does not seem to be any air in the rads or the pump. I can find no leaks. The pump is working. The 2 port valve I know is kackered as it heats the rads when on water only. The header tank has water in it and the valve is working.
I suspect you are going to tell me the cold feed pipe is blocked again but why would that make a difference since I have not drained the system?
Not unreasonably I can not get hold of my usual H&C corgi man. Any suggestions?
