Problems bleeding radiators
12 Oct 2006
Manchester
I've recently moved in to a house with quite old radiators, they are covered in layer upon layer of paint so now the bleed valves are completely covered. Is there an easy way to either
a) remove the paint from the valves and get them working
b) an alternative way of removing the air from the radiators
c) or am i just better off replacing the lot.
I also have an old heated towel rail in the bathroom. I tried to bleed it but the valve was stiff. I got a pair of mole grips onto it and the end of the valve twisted off!
Any ideas? Is a bleed valve replaceable?
Can you post a photo? Often there is a plug screwed into the top end of the radiator (same size as the hole for the valves) and you can replace this plug complete with bleed screw.
id replace the airing valves, if youve got a 22mm socket it will be easy and only cost a bottle of fernox and b"""hair less than a 10er for the valves. kind of depends on you, as if you think the rads are about as good looking on your walls as billie the singing bass then id change the lot out
