Hiya.
At a loss as to what to do next with this boiler!
Heating does not respond to the timer. Every time it reaches the programmed 'switch on' time it does not ignite so you have to manually start it going by pressing the red cut out button.. The heating does turn off when its supposed to though.
Also, the water is very tempermental. It takes ages to heat the water for the shower & then it gets hotter & hotter & you have to keep fiddling with the taps too get a reasonable temp.
These are hopefully the last in a series of problems that I have had.
So far the main board has been replaced & an over heating valve type thing has been replaced.. Im now told it could be the air pressure switch. Im going away for several months in Feb a need the timer to be working effectively whilst Im away.. Any help would be very much appreciated.. As you can probably tell I havent a clue about boilers so I need any advice in simple language please
Many thanks...
