Problems with New-ish Drayton Radiator
10 May 2010
Hertfordshire
I live in a new build property (10 months old).
I went to turn on our living room radiator this evening and could not move the thermostat at all (admitedly it had been put to 0, which I now realise was a mistake).
I removed the white platic cap, by loosening the nut just underneath, until it came off. As soon as I did this hot water began flowing through the entire radiator.
However, the adjuster on the white cap is still stuck solid. I'm afraid that when I put the cap back on it will not be able to adjust the water.
Any thoughts of comments please, I'm a complete novice!
SOme additional information.
The valve is a drayton rt212
The brass pin that is now visible can be pushed down but only about 3mm, even though it is about 10mm long.
Is it meant to be able to pushed al the way down or is 3mm about right?
The pins dont move very far. It is probably just the head that is stuck. If you can't free it up, take it along to a plumbers merchant and buy a replacement then just fit the new head onto the old valve.
Possibly but there are so many different TRVs that it would be a real stroke of luck if they had the one you need. A good plumbers merchant will have it on the shelf or be able to get you one in a day or two. Or you could buy online.
