Recently i removed a radiator for some decorating however i notice a damp patch on the wall a few days later and found that the outlet valve on the 10mm microbore piping was seeping slightly so i tightened it and it cured the problem.
However today i cam to refit the radiator and as i did so the valve moved and in doing so created an even worse leak i have tried numerous times to tighten and fix but to no avail so have resorted for now in draining the system until i can fix. Anyway can anyone tell me what could cause the problem i canot get the olive off and cannot see any cracks in the pipework. also would puch fitting be sufficient in a repair.
