I have a Procombi 85 HE that has been installed for around 4 years. I'm having a problem where the solid red light fault indicator is showing and the boiler is shutting down.
This happens when water and heating is selected, usually after around 30mins. It also happens occasionally when only hw is selected.
I usually switch the boiler to off position (not at the wall) and wait a few minutes before switching it back to hw and ch when it will start working again for around 30-60mins when the problem repeats.
The boiler has around 2 bar pressure.
I've done some research online which points at thermistor and PCM faults, hoping someone on here can point me in the right direction please!
Thanks,
John
Thanks,
John
