- Joined
- 1 Nov 2004
- Messages
- 30
- Reaction score
- 0
- Country
Hi all,
looking for a bit of advice (as im sure many will be now the cold weather is here
i have a ravenheat csi 85 gas combi boiler.
every few days the boiler stops working with a constant red light on and the fan whirring away. this happens regardless of of the boiler being used for CH or DHW
Consulting the manual reveals the a constant red light signifies flame failure.
Now having read through a fair bit of this forum i ahve done a few checks recomended in other posts.
I have looked into the condensor drain/trap on the bottom to see if it is blocked, the rear side has water in it that flows into the empty side then out through the drain pipe. Is this how it should be?
also i have read that the thermistors are common weak points (part number 0007TER05005/0) could this be the cause of my problems.
Thanks for reading
dave
Thanks for reading
dave
