Hi Guys, wonder if anyone can help me.
I've got 2 exterior wall lights either side of my front door, along with an illuminated house number plaque type thing. I want to be able to program the times at which they come on and off, but I also want to be able to override the set times and turn them on or off using a normal indoor light switch.
Basically I want the timer control part to be hidden away in a cupboard, but I need the normal wall switch to be near the front door. I've seen a few programmable timers that have an intergrated override switch, but I want the override switch to be sepearte so I can place it anywhere I like.
Has anyone done this before or know of what product would allow me to do this?
Extending this a bit further, would this be possible:
1. Lights are programmed to come on and off at set periods i.e. 6pm - 12pm.
2. Lights can be overidden to come on or off with a manual EXTERNAL light swich - i.e lights are programmed to be on but I want to turn them off using a normal wall light switch (or On and vice-versa).
3. Lights can be wired into a PIR sensor of some sort so that they'll act as a security light - i.e. from 12am - 6am they function as a normal security light when they would normally be programmed to be off.
Any help much appreciated!
Thanks, Phil
Thanks, Phil
