hello. is it possible to use a dual programmer ie hw,ch with a combi or must programmer be single use ch only? bought wrong programmer as was day dreaming !!!cheers
With my recently installed Worcester 18/25 Combi I was supplied with a Honeywell ST900A 2 Channel Programmer for Hot Water and Central Heating. (Google it ).
This is used in conjunction with a Honeywell T 6360.
It depends whether the combi heating contacts are mains switching or low voltage.
If you connect a Drayton to the latter you could destroy the combi PCB.
PS: The ST9000 is the 1 day version of the ST9400C, which is 7 days. Otherwise its the same, we only specify the 7 day version so I was not familiar with the number. Sorry about the confusion. My comments above regarding the boiler application also refer to the ST9000 series.
