Ok, so the plan is to connect solar primary circuit to lower coil in a solar unvented cylinder, which will provide the DHW. So far so good, all as normal. The twist is that I have a 300l Megaflo Direct cylinder that i want to use as a thermal store (because I got it for free).
What would happen if I used the upper coil in the solar unvented to take heat from the solar unvented cylinder and pump it into the Megaflo which would be a tank containing the space heating primary circuit water? This would only happen when the DHW cylinder has satisfied temperature. The upper coil is in the middl so there should still be a bit of hot DHW in the top.
The upper coil in the solar twin coil cylinder s meant to be used the other way round, to put heat into the cylinder (from a boiler or whatever), so i wonder if it will be effective to 'steal' heat from the heated up DHW unvented solar cylinder?
