I have a two coil 170 Litre gledhill torrent thermal store. the primary coil is heated by my oil boiler and the mains water runs through the secondary coil where it is heated.
The water in the cylinder is static.
Question, I am wanting to add solar, preferably without replacing the cylinder as it is not that old. I notice that with some thermal stores the boiler heats the store water directly, i.e there is no primary coil, the water which in the gledhill is static is simply circulated by the system pump through the main boiler..
Would it be feasible for me to do this with my gledhill and then use the primary coil as a heat exchanger for solar panels.?? Is there some technical reason why this wouldnt work?
Any thoughts would be greatly appreciated.
Kind Regards
Paul
Kind Regards
Paul
